GPS BLUETOOTH
GPS BLUETOOTH
Postby PROPMAN » 29 May 2014, 15:45
I don't have a button to select external Bluetooth GPS?
PROPMAN
Re: GPS BLUETOOTH
Postby Onuff » 29 May 2014, 20:06
1 parameters of the developer-----> arrangement emulation - X
2 FIF-->app settings ---> Preferences --->sensors settings ---->GPS source --->>bluetooth GPS))))
Re: GPS BLUETOOTH
Postby skytalk » 20 Jun 2014, 08:45
You can download "Bluetooth GPS" app from Google.Play (free of cost), connect your Bluetooth GPS Antenna to your Android device through this app, and then you don't need to choose GPS data source in FiF settings. In this case you can use any GPS app with your external GPS Antenna. I do so with my Galaxy S4 and Skypro XGPS160.
skytalk
Re: GPS BLUETOOTH
Postby martinjs » 12 Oct 2014, 13:20
I have been using Bluetooth GPS Provider before and was very happy, when FiFu offered to connect directly to my GPS-mouse. I had serious energy problems with the combo mouse-bluetooth-gpsProvider-FlyisFun and I hoped this would be a little better, little because the main drain is the bluetooth. But my Tab needed just a bit more energy than the USB input could provide, so maybe it would be enough.
However I do not get it to work, the combo works fine, but when I activate bluetooth, pair to my gps mouse, switch FiFu to Bluetooth and select my mouse, I only get a red north-symbol.
I tried a different mouse, I tested it on my phone, but the same result.
Did I miss something ?
martinjs
