ATZ areas and airfield traffic patterns
Postby radekw » 15 Sep 2014, 07:08
Hi, how can I view in map ATZ areas and traffic patterns? It's possible? Thanks.
radekw
Re: ATZ areas and airfield traffic patterns
Postby radekw » 15 Sep 2014, 07:38
ATZ is no longer displaying. Now more traffic patterns :-) Thanks.
radekw
Postby kitercuda » 16 Sep 2014, 09:45
ATZ
- Long tap to compass rose for customizing the screen
- Roll down and select zoom level
- Press Airspaces button and check ATZ (for each zoom level which you want to see)
Traffic patterns are available only for Gramny, Austria and Switzerland at this time.
Postby radekw » 26 Sep 2014, 18:23
Can You write me the best way, how I create trafic pattern kml file to import in navigation database? I try it in Google Earth, but result isn't good. Pattern is deformed, how I manually drawed it. Thanks for your answer.
radekw
Postby kitercuda » 27 Sep 2014, 03:11
Can you sens me a sample of your KML?
If you have the coordinates, the best way is to create OpenAero txt file. Do you have them?
