Editing Routes Problems
Postby B21 » 06 Aug 2015, 10:25
Hello.
Since the present update the routes (which are still existing) are not editable anymore.
Any hint to solve this probleme
Many Thanks
Frank
B21
Re: Editing Routes Problems
Postby kitercuda » 08 Aug 2015, 09:08
Can you describe where is the problem? I can edit route....
Postby B21 » 08 Aug 2015, 12:09
Hello.
If I want to correct or change some legs of a route, I go to navigate/route/ than long tap on the saved route I want to change /edit /route with the listed navlogs apears / tap on button with the world pictured / than the topo map apears, but without any navaids, airspaces and without route/ tap on "go back button" / route with the listed navlogs apears again / tap on button with the world pictured two times in series/ than the topo map apears, now with navaids, airspaces an the route pictured.
Now: drag an drop of the legs is not possible (topo map will move instead). If I tap on a navaid on the topo map the only thing I can do is to confirm "route" button on the popuped info box, but than a new route will beginn, and that is not what I want to do.
Do you have a hint to solve this probleme, or maybe to go back to version 17.01 or 17.00?
Many Thanks
Frank
B21
Postby Viking » 08 Aug 2015, 15:51
HI,
Just for information, for me, version 17.10, all is correct, I can change or edit a saved log.
Jean-Pierre - LFFD.
Postby B21 » 08 Aug 2015, 16:17
Hi.
Thats roger,
But not very helpfull, isnt it.
Lucky man.
B21
