Versions 18 - 19
Versions 18 - 19
Postby kitercuda » 30 Mar 2016, 06:16
Version 19.90
- PDF can be automatically downloaded when importing the world database (at this moment there are only Czech PDFs available). Data are downloaded to folder PDF_system.
- Added plane type: Touring motor glider
Version 19.85
- Added country code to nav items
- Fixed displaying at screen ratio bigger than Full HD (for example Galaxy S8)
- Removed some minor bug
Version 19.84
- Possible using external Bluetooth baro sensor (Menu/App settings/Preferences - Extrnal sensors)
Version 19.83
- Possible change aircraft symbol size (map - customize screen)
- Better visibility of map objects labels
Version 19.82
- Added AGS: Average ground speed
- Possible to set Logbook GPS fix update interval to 1 second
- Updated Lithuanian version. Thanks to Edvinas.
- Removed crash: Nav database searching (pressing enter button at soft keyboard)
- Internal changes
Version 19.81
- Improved info dialog (you can for example top map, when it is displayed)
- Refactored intent filter (better working with email attachments).
Version 19.80
- Vertical navigation to any WPT (not only ILS). Press WPT icon at nav database and select VNAV.
Version 19.71
- Internal database import changes
Version 19.70
- Logbook: possible select more records (swipe to left) and then assign Pilots or aircraft to all selected records in "one click"
- Route list: Exporting Flight log in XLS data format. You can create your own template.
- Updated Czech, German, French, italian, Polish, and Spanish version. Many thanks to Juergen, Antoine, Marco, Krzystof and Rolando
Version 19.62
- Removed bug, when exporting FPL to XLS.
Version 19.61
- Possible assign aircraft or pilots to selected rows in logbook. Select desired rows (swipe them to the left), long press on one of selected row and select Assign aircraft or pilots.
- Fixed bug: When merging logbook rows, the flight distance was sometimes shorter...
Version 19.60
- Refactored VHFs. You must update Nav database
Version 19.52
- Updated Czech, German, French, italian, Polish, Spanish and Russian version. Many thanks to Juergen, Antoine, Marco, Krzystof, Rolando and Alex
- Changed colors of active items in Nav database and Routes.
- Flight plan starts working - for testing only!!! Long press at the route at Route list and select Flight plan or at the main screen Menu / Tools / flight plan.
Flight plan is created by Pilot, Aircraft and Route. So it is recomended to fill all field for pilot and aircraft before creating fligh plan (Aircraft list, Pilot list).
Version 19.51
- Internal changes
Version 19.50
- Aircraft edit fields was extended (check list, values for baro altitude correction, flight plan fields)
Version 19.44
- Added ETA to NAV1, NAV2 minutes and seconds
- Possible set terrain transparency and shade for terrain at map screen
- Updated Czech, German, French, Italian and Spanish version. Many Thanks to Juergen, Antoine, Marco and Rolando
- Removed some bugs
Version 19.43
- Route summary improved
Version 19.41
- Pilot list refactored. There are more fields (email, telephone, www, airport, address). It is possible also to select active pilot by pressing circle button in the list.
- Aircraft list - It is possible to select aircraft in use by pressing circle button in the list of the aircrafts.
- Updated French and Polish version. Thanks to Antoine and Krzystof.
Version 19.40
- Routes was refactored (Thanks to Juergen for his help)
- Now it is possible to select wind for each route leg before calculating route summary. Swipe route leg from left to right for displaying route leg details.
- Possible to select 2 alternate airports for each route. When calculating route summary, you can see the fuel, distance and estimated elapsed time to the route end + flying to to alternate airport.
- When flying route, you can easy select direct to alternate airport (Menu / Navigate or Route window and press alternate airport)
- Updated Czech, German, French, Italian, Russian and Spanish version. Many Thanks to Juergen, Antoine, Marco, Alex and Rolando
Version 19.30
- In the map screen is possible to switch on terrain displaying (long press for screen customizing the compass rose)
- Route is refactored. Possible to fill wind for each leg }used for summary and FPL).
- Updated German, Italy, Polish and Czech version. Thanks to Juergen, Marco and Krzysztof.
- Removed bug
Version 19.24
- Updated Spanish version. Thanks to Rolando.
- More zoom for vertical cut - up to 25nm / 50km. Default value is 6nm / 12 km. Possible to set max zoom for vertical cut in preferences.
- Possible select, which altitude is using for recording your flight track (Preferences / Logbook / Altitude for recording)
- When you create route (Route edit activity) - Each WPT has 3 info strings, which can be used for flight plan (coordinates, position related to nearest APT, position related to nearest VOR). If you do not like it, Preferences / Route.
Version 19.23
- Updated Czech, German, France, Italian, Polish and Russian version. Thanks to Juergen, Antoine, Marco, Rolando, Krzystof and Alex.
- Removed bug when app launch and crash
Version 19.22
- Refactored max terrain elev calculator, especially landscape mode
- Route edit - Calculate max terrain elev on one click
- Removed bug
Version 19.21
- Refactored terrain data, Terrain screen zoom up to 25nm / 50km
Version 19.20
- Added GPS vertical speed
Version 19.12
- Refactored all yes/no dialog boxes
Version 19.11
- Refactored all combo-button menus to new design
- Removed minor bugs
Version 19.10
- Refactored all menus to new design
- Better file dialog
- Removed some bugs
Version 19.02
- Refactored menus in Nav database, Routes, Logbook, Pilots and Aircrafts
- Better landscape mode for Nav database and Routes
- Nav database - for quick navigation menu tap nav item icon at the left
Version 19.01
- Updated German, Spanish, Polish and Russian version. Thanks to Juergen, Rolando, Krzystof and Alex.
Version 19.00
- Refactored all menus in main activity.
- Updated French, Italian and Czech version. Thanks to Antoine and Marco.
Version 18.41
- Updated Spanish, Italian, Polish, Russian and French version. Thanks to Rolando, Marco, Krzystof, Alex and Antoine.
- Added NAV2 ETA (UTC and LT)
- All UTC values have black background
- All LT values have dark green values
- ETA has 3 digits color (like a DME for NAV1, NAV2, Route)
- When route is paused, value windows stil displays route values (ETA, DME to the route end)
Version 18.40
- Updated Spanish version, thaks to Rolando
- A lot of new settngs for HSI and PFD. Preferences - Ranges and distances / HSI and PFD settings
Version 18.32
- Added XAL value = ALT - CAL (used for ILS aproach). XAL displays how many feet (metres) youa over/under glide slope.
- Route can be also started by long map tapping.
- Removed some minor bugs
Version 18.31
- Updated German, French, Italian, Poland and Czech version. Thanks to Juergen, Antoine, Marco and Krzystof.
- When you create new WPT by map long tapping, WPT notes is filled by radial and distance related to nearest APT or nav aid (VOR, NDB). You can change the units in Preferences.
Version 18.30
- Integrated Aeolus Sense (Menu / App settings / Preferences - External data source / WiFi)
http://www.talosavionics.com/product/aeolus/
Version 18.24
- New OpenFlightMaps available for Austria, Denmark, Germany, Hungary, Romania, Switzerland. Thanks to Oliver from http://openflightmaps.org/
Version 18.23
- Added German version of user guide. Thanks to Kurt.
- Possible import Slippy mercator maps (tiles in folders). Menu / Downloads / Maps, Menu / Impport...
Version 18.22
- Improved Position info
- Removed bugs
Version 18.20
- Tapping values BRG, RDL, ET, ETA for NAV1 displays info box like you tap NAV1 at the map
- Tapping values BRG, RDL, ET, for NAV2 displays info box like you tap NAV2 at the map
- Launching FIF info page is faster
- WPT info dilaog box (after tapping map object) displays RDL and BRG also in geo directions (N, NW, W, etc). This directions are always true, not magnetic.
- Refactored Position info (Menu / Tools and info / Position information). Also available after tapping map aircraft symbol.
Version 18.14
- Enabled SD card for Marshmallow
Version 18.13
- Updated German version, thanks to Juergen.
- Possible setup min dist between tvo WPTs at the route.
- After touching RMZ or Airspace pattern application displays also VHF.
- Next route info box displays VHF (if possible)
Version 18.12
- Updated French, Czech, Italian and Poland versions. Thanks to Antoine, Marco and Krzystof.
Version 18.11
- Refactored Helper. Helper was also renamed to FLY is FUN info. If you want to switch-off it at the startup, open Preferences / Screen settings
- Possible select unit for RWY dimensions (feet or m)
Version 18.03
- Alarm clock can ring periodically (When it is ringing press the Repeat button)
- Removed some bugs
Version 18.01
- FLY is FUN helper on start-up (Menu/downloads).
- Added Lithuanian language. Thanks to Edvinas.
