Import Elevation data - Bad header
Re: Import Elevation data - Bad header
Postby kitercuda » 20 Dec 2013, 09:20
Samples are here:
Rectangle:
Latitude 80N-85N
Longitude 035W-030W
http://www.funair.cz/downloads/elev/new ... W-030W.zip
Latitude 80N-85N
Longitude 045E-050E
http://www.funair.cz/downloads/elev/new ... E-050E.zip
Coordinates must be divisible by 5.
Unzip file and copy to folder ElevationData.
Postby barneo66 » 22 Dec 2013, 00:36
Hi Peter!
Need the address to download the relief above the 60H on the PC then to import.
Big Thanks
barneo66
Postby kitercuda » 22 Dec 2013, 07:58
Address is here. If you need another 5x5 degrees rectangle, rewrite coordinates...
http://www.funair.cz/downloads/elev/new ... E-035E.zip
Postby barneo66 » 24 Dec 2013, 02:58
Ок!!!
Thanks!
Merry Christmas and Happy New year !!!!
barneo66
Postby skipmick » 01 Oct 2014, 21:47
I cannot find the import data on newer version. Can you update it and put back on this way? Press Menu / Tools / Import elevation data
skipmick
Postby kitercuda » 02 Oct 2014, 06:20
Sorry, it was removed, because it is not necessary any more. SRTM data will be also removed soon, because there will be some changes at the terrain data.
Use Menu/downloads/Terrain data manager
Postby pjp » 02 Oct 2014, 18:03
Locus and OruxMaps use hgt files (DEM ?), maybe will be better to use this data ? Of course, if any ...
Pavel
pjp
