Page 1 of 2
Map decluttering
PostPosted: 28 Apr 2014, 19:51
by mmoeller
First of all I'd like to congratulate with You for your superb software: runs smooth and is really cockpit oriented. Hard to find qualities, specially the latter.
How can I declutter the map?
In my area (north of Italy) the map appears overfilled by UL airfields which makes it uselessly difficult to locate WPTs and/or navigation relevant points graphically on the map.
Is there a way to hide such fields? Fields with no ICAO code.
Thank you
Re: Map decluttering
PostPosted: 29 Apr 2014, 10:47
by Eliseo
Hi.
I have the same problem, I have my fields waypoints ULM
and overlapping of FiF database. I think there is a problem
with "service, no service" fields.
I think it is more important classify the fields with ID. OACI
and the fields without OACI. eg ULMs
PostPosted: 29 Apr 2014, 12:18
I at this time you can Customize screen (long tap compass rose) and uncheck Non-serviced for all zooms.
I had a look the airports with code like PR05, PC06 etc. I can mark them as UL field. Then it will be easy to remove them from map.
Is it OK for you?
PostPosted: 29 Apr 2014, 12:53
by mmoeller
"non-serviced" unfortunately does not help as even some "airports" are un-serviced.
The only solution is the UL tag.
If there is a way I may help you in this tedious work.
PostPosted: 29 Apr 2014, 17:16
Thanks, it is not so much work for me. I will do it :-)
PostPosted: 29 Apr 2014, 17:56
by mmoeller
To be honest it took only one sql query to do it.
I guess, I only have to repair the db after every import.
PostPosted: 01 May 2014, 06:22
It is a little bit more work - the source is in csv format :-)
PostPosted: 05 May 2014, 08:34
by Eliseo
kitercuda wrote:I at this time you can Customize screen (long tap compass rose) and uncheck Non-serviced for all zooms.
Is it OK for you?
Hi.
For me it is enough.
Can you please explain me how to make all the display settings are in all zooms,
I have not been able to ascertain.
PostPosted: 05 May 2014, 13:50
1. Open Customize screen dialog (long tap compass rose)
2. Select zoom level by tapping it and selecting the value
3. Set what you want to see (check boxes bellow zoom level)
4. Repeat 2-3 for all zooms
5. Press Save
You must set each zoom level!
PostPosted: 06 May 2014, 10:03
by Eliseo
Thanks.
could I hide my personals waypoints at any zoom level?
Edit:
sorry I just saw
