Stratux intergration
Re: Stratux intergration
Postby hingbay » 08 Jun 2018, 04:08
Hi Peter,
I am a regular user of FlyIsFun in Australia and I am a big fan of all you have done. I have a shop bought brand new Stratux box which I can post to you if you have the time to play with it. Integration of ADSB equipped aircraft positions onto your moving map would be fantastic. Over WiFi the box puts out Squawk, Flight No, Altitude, Speed, Heading, Latitude and Longitude of aircraft in range up to 20 Nautical Miles. No internet required, it just reads pings from surrounding aircraft.
I would want the Stratux back when you have finished of course! But it would be that useful to me to have support for FlyIsFun I can do without it if it helps development. I note that others have posted they would also like to see Stratux support.
Regards,
Phillip
hingbay
Postby kitercuda » 30 Aug 2018, 04:52
Hi Stratux is on my table. The problem is only to find time to implement it. In the past I worked on FIF 7 days a week, but now it is impossible. I must earn some money with another projects to support FIF.
Postby kitercuda » 29 Apr 2019, 16:22
Stratux is implementing now :-)
Postby Tonio » 30 Apr 2019, 22:46
YES !!!! Super
When will you release it?
Postby kitercuda » 03 May 2019, 11:20
Maybe next week for testing...
Postby kitercuda » 07 May 2019, 17:48
First aircraft from ADS-B source displayed at the map :-)
Postby Tonio » 08 May 2019, 21:10
Great news !
Postby kitercuda » 09 May 2019, 17:16
Hi, I just published version 22.00 with Stratux support. It is possible to use it now.
I want to implement:
- Possibility to hide aircrafts if the vertical distance is more than ...
- Predict aircrafts position using coordinates and vector (if FIF has no ADS-B data update)
- Warnings
Postby Tonio » 10 May 2019, 17:56
Just great !!!!
Tested today in Tunis, where I leave
Youpi
Postby hingbay » 14 May 2019, 10:30
Hi Petr,
Great news!. I used the Stratux box today with FIF and like Tonio said,it is fantastic! I really appreciate your hard work on this. It is very handy around busy airports.
Thanks!
Phillip
hingbay
