Argentina Airspaces/Airports
Postby v01d » 28 Nov 2014, 13:18
I've noticed some errors on airspace definitions and some incomplete data (missing runway information, etc.).
There is a KML map with a lot of correct data which I could download and tag appropriately.
How could I submit this in order to correct the current navdata on flyisfun?
Also, when importing the KML data, will I have everything duplicated with data on original database or how can I deal with this?
v01d
Re: Argentina Airspaces/Airports
Postby kitercuda » 28 Nov 2014, 15:57
I am working on database upgrade, there will be new airspaces.
If you import KML and do not delete data in the folder World database, data could be duplicated.
Postby v01d » 28 Nov 2014, 16:39
Ah, so you are considering updating also Argentina's airspace?
In case you need a reference, here you have Buenos Aires's part, where there are several errors:
http://186.153.175.229/descarga/aip-520a78f72d261
The airspace classes are listed on the table to the right. Note that also there are VFR corridors which should be included as airspaces.
If you need any help adding this data, let me know.
v01d
Postby kitercuda » 29 Nov 2014, 17:58
Thanks a lot.
I will have look.
