alternative purchase options
PostPosted: 24 May 2016, 00:37
by flynav
Is there an alternative to the playstore to purchase a license?
And then I have a few suggestion/questions. I found this app searching for an app that emulates the functionality of a Garmin GPSmap 196.
For weeks I didn't find anything closely comparable. Fly is FUN is great and powerful, but lacks a few little things I used in a GPSmap, namely:
- The HSI dots were linear, not angular or logarithmic and could go as low as 0.25nm for 5 dots, so 0.05nm per dot (important for survey flights).
- GPSmap has a field "TURN" which tells you how many degrees to turn left or right to get back on track
- the cross track field switches to m or ft instead of 0.00x nm
- there's free US VNCs and Canada VNCs and integration of those would pretty much eliminate my use of FLTplan GO
Thanks a ton for making one useful app with a great user interface that lets one operate efficiently even in flight. Almost as good as Garmins GPSmap!
Re: alternative purchase options
PostPosted: 24 May 2016, 17:10
by japax
Just for curiosity, how much it cost to use Garmin?
PostPosted: 24 May 2016, 18:50
by flynav
Oh the Garmin GPSmap x96 is not an app, It's a hardware device, unfortunately no longer produced and it was really expensive. But is was perfect for helicopter flying and has a great UI with its buttons. Really great design - 100 times better than GNS430.
It cost around 800$ but that was ten years ago I think.
