Navigation
Navigation
Postby geewhiz » 28 May 2015, 14:22
Navigation
Hi Petr. Not sure where to put this. First of all... Your software is a brilliant piece of work. However, it's too complex to take in from your user guide, (unless its me...). The facilities and information while flying are superb, but maybe I am looking for what doesn't exist.
I live in an area of complex airspace. What I would like to be able to do in the comfort of my home is to route plan in detail direct to device, skirting problem areas. So if I put in a start airfield and an end airfield, and then pull the track about to keep me out of trouble so that the display shows the required zig zag flight path for the entire journey, that would be perfect. Maybe the software can do this already and I stupidly can't see how to do. A navigation tutorial on YouTube might be a good idea. I can't be the only one out there who is defeated. Can I....?
geewhiz
Re: Navigation
Postby kitercuda » 30 May 2015, 09:19
I am planning to improve roiutes, so it will be implemented. It is one of my proirity to implement routes now.
Re: Navigation
Postby geewhiz » 30 May 2015, 17:46
Petr. I understand how demanding it is to write good software. You are a Superstar and most of your users are very appreciative of what you have done. Data is King... I can't ask for more from you but I know what it is to let your obsession run. Keep it up and take pride in your achievement. I am sure that you will develop the most complete flyware on the planet, and I raise a gin and tonic to you. Cheers....
geewhiz
Re: Navigation
Postby kitercuda » 02 Jun 2015, 12:10
First time I read I am superstar :-) :-) :-)
