UK New 8.33 Frequencies
Postby flyyyer » 04 Jan 2019, 19:21
Hi All,
Be aware many/most of the airport frequencies in the UK have now changed to accommodate the 8.33 khz spacings and it is now technically illegal to use 25 khz spacing set, although many "major" frequencies such as London inf are OK. There is a lot of out of date information on the internet, the best up to date info I have found is https://www.newfrequency.co.uk .
Also http://www.nats-uk.ead-it.com/public/in ... d=354.html is the official list but it doesn' t show unlicenced airports.
@kiterkuda Hi Petr Can the UK frequency list in FIF be updated now the the transition has more or less finished now. I can help if needed.
Re: UK New 8.33 Frequencies
Postby kitercuda » 23 Jan 2019, 20:22
Thanks, we are working on it.
Postby flyyyer » 16 Apr 2019, 12:37
Hi Petr.
Just checking on any progress on UK 8.33 frequencies before the weather gets too good and you get too busy. If I can help , I will....
Postby kitercuda » 03 May 2019, 10:04
Thanks Peter,
big airports are upgraded now (AIRAC 1905). With small airports I will need some help.
Petr
