Page 1 of 2
CUSTOMIZE SCREEN check boxes
Posted:
28 Apr 2013, 00:18
by francojb
Hi!!!
I´m sorry but I can´t understand the logic of the CUSTOMIZE SCREEN check boxes. What has to appear when one is checked or unchecked. Because some icons appear when it ch box is checked and when is unchecked they appear, too...
thank you!!!!
Re: CUSTOMIZE SCREEN check boxes
Posted:
29 Apr 2013, 18:47
Look at new user guide, customize screen
http://www.funair.cz/downloads/manuals/flyisfun.pdfAre they user defined items? Maybe you have checked
Force displaying all user defined items.
Posted:
02 May 2013, 13:00
by francojb
Hi Petr!!
No, I don´t have cheked "Force displaying..." and they are not "user defined" either...
For example:
- If I check no check box, every item appear
- If I check only "Force displaying...", every item appear, but if I check "Force displaying..." and other item ch box(apt, vor, ndb, etc) but no VFR, IFR or Not Specified, no item appear
- If I check apt and all its sub ch boxes but I don´t check Not Specified, no apt appears
- If I check wpt, IFR and Not Specified but no twpt, twpt appear, too...
Posted:
14 Jun 2013, 11:27
by Eliseo
How thoughtful! zoom to 120 Km
One suggestion, I think the zoom buttons should be at the bottom of the screen and the information up (batery, escala the zoom, etc) I think look like more professional.
when you press the zoom button you not can see the screen.
I'm doing 7-12 scale maps (MOBAC), is that correct?
Posted:
15 Jun 2013, 20:15
by Onuff
hello!!!
there is logic
and Ergonomics
and everything under the right or left thumb
Posted:
17 Jun 2013, 04:41
Hmm - you are right - it is more ergonomic (when you keep device in your hand)
I will think about it...
Posted:
27 Jun 2013, 20:33
by Onuff
with possibility of a choice
and possibility of a choice of a skin
Posted:
15 Dec 2013, 12:39
by marpdiaz
Hi Petr,
I found that NOT SPECIFIED check box for TWPT is locked for zoom 10 mn up to 60 nm. Our TMAs are oversized so I really need to see those non-specified TWPTs in zoom 10, 15, and 25. I tried to check the "force displaying of all user defined items" but the non-specified TWPTs are still missing in the map. The NOT SPECIFIED check box is ok (i.e. open for change) for levels 0.25 to 6 nm.
VRP check box is ok too.
best,
Posted:
15 Dec 2013, 21:21
In Europe, we have really a lot of TWPTs - is somebody check it for zoom 60, application probably crash for Out of memory.
Posted:
16 Dec 2013, 00:55
by marpdiaz
I see..., well, zoom 10 and 15 would be OK, if possible.
