Terrain Awareness page broken
Postby xaxero » 07 Aug 2017, 19:37
Just took my updated tablet flying today and found the terrain awareness page is badly broken since the update.
I use this feature a lot.
The system is cycling through several aircraft altitudes and the display is totally meaningless.
I tested with Google Nexus 6 and Samsung Galaxy note 4 and we get the same results - pressure / GPS altitude source no difference. Altitude above ground is correct - the map display only is meaningless
I am planning on some mountain flying on Tuesday so would be good to get this working.
xaxero
Re: Terrain Awareness page broken
Postby marpdiaz » 10 Aug 2017, 22:40
Hi Xaxero,
You may try to unselect "Use projected flight path for terrain colors" in Application settings, Customize Screen.
When set FiF use your current climb/descent to predict ground proximity. if your climb rate change or fluctuate then the terrain map color coding will change as well.
This is just a guess. The problem may be elsewhere.
