navigation needle
navigation needle
Postby droopstop » 26 Dec 2012, 17:47
Is there any chance of putting a tail on the navigation needle so we can track away from a waypoint please
droopstop
Re: navigation needle
Postby kitercuda » 02 Jan 2013, 10:38
I do not understand. If you mean TO/FROM indicator it is present on compass.
Postby vooger » 16 Jan 2013, 18:36
Have a good time! It would be good that the application has a window that shows the lateral deviation. i mean, for example, an arrow with numbers for indication the side and lateral distance
vooger
Postby kitercuda » 18 Jan 2013, 13:00
I still do not understand :-)
If you mean look at XTK (Menu/App settings/Customize screen)- cross track distance - cross distance from track or route.
Postby droopstop » 24 Jan 2013, 21:00
It's not a request for a to/from indicator mate. When flying towards a beacon you would use the head of the needle on the HSI to maintain a radial inbound. When tracking away from a beacon you would use the tail of the needle to maintain a radial outbound. The blue needle on your HSI only has a head and so can be used for tracking towards the waypoint only. Can you put a tail on the blue needle mate, hope I've managed to explain better
droopstop
Postby Breitling » 29 Jan 2013, 16:17
I think droopstop refers to what I show you on attached image. See these other examples:
Breitling
Postby kitercuda » 30 Jan 2013, 06:56
Hi, thanks - good suggestion, next upgrade will have it.
Edit: done, next upgrade will have it
Postby droopstop » 10 Feb 2013, 17:57
Well done Breitling the HSI picture explained it very well. I've just seen the update and the needle tail is brilliant Petr, many thanks mate
droopstop
