terrain screen in landscape - nbr columns/rows
Postby RogerF » 22 Jun 2019, 21:41
I am currently using FIF in Landscape view as my MiMax (6.5") fits well on my kneeboard in this position.
I also started configuring the "terrain" screen with this orientation.
My first impression is that the size of the different elements is not well balanced: the 6 selectable elements are "giants" with respect to the other elements.
My suggestion would be to allow for displaying 3 columns / 5 rows instead of 2 columns / 3 rows.
This would give a more balanced view while allowing to show more selectable elements in the "terrain" screen.
The two snapshots show the proposal 3x5 and the current implementation 2x3.
You could even consider implementing 4x6 as this would show most of the values using similar having the same sizes.
Thank you in advance for investigating this proposal.
FIF Landscape - Terrain screen (proposal).gif (76 KiB) Viewed 8286 times
FIF Landscape - Terrain screen (currently).gif (73.45 KiB) Viewed 8286 times
Re: terrain screen in landscape - nbr columns/rows
Postby kitercuda » 08 Jul 2019, 17:49
It looks good :-)
After implementation the weather...
Postby Tonio » 14 Sep 2019, 22:41
Sometime Petr introduce new function without advertising them
Who did notice, that elevation data / terrain data can now replace the moving map as background of the moving map screen?
On moving map screen,
-> long press on compass rose
-> select "Display terrain (only when Log is activate)"
If you do that, when flying, you will get terrain data replacing the moving maps
Instead of having it as an option of the moving map screen, I would appreciate, having it as one more screen
